Clean Look... TEMPORARY...
Since people are learning this format...
I switched off the All American formatted skin...
This is very clean Hence the name and I figured until you guys all see the menus and learn your way around...
This would make it a little easier even though Its to me not as snazzy...
if you would like to change it scroll down to the bottom usually right of center or Center
Look to see the THEME tab if you select it a drop down will fly out and you can cycle through some of the other skins I have not debugged them all so you may not see through a button and see text or the colors may be  a touch off we did a lot of work before and I was about a month away from tossing the site out and saying it was truly 100
It has a lot of features and add ons in other skins like jeep slide show at top of page and other things like that Ticker tape so I can put a message up like countdown till a certain day for whatever reason...
So for now you can switch to whatever view you like the best I have now set this page to default load in Clean mode also if you look up at the Top near the top just under the Tabs I think you will see a Mode Toggle thats dark to light 🙂
Thought yall may like that feature also...
I also have some other heavily modified themes and Ill be working on them all later...
For Now Enjoy
PS
Yall gotta agree its a lot easier to read my stuff now... I think?
Im crashing
