August 23, 20205 yr Admin Hey this is pretty big news , the 4.5 update is out . This adds some good functionality and theme improvements.It will probably break a bunch of shit but hey that’s what we do right ?
August 23, 20205 yr Admin I (ah in the All American dark I cant see when and what im typing in hardly can you correct that please...? lol Also we got the site updated cool... I had the easy part upload and break... Hahahaha Here I go Again... Mark@AmericanJeeper.Com
August 23, 20205 yr Admin Plus this one is the one after you reply in all American Dark it refreshes and you see your response with everyone elses so thats when it needs some serious looking into by You sir...lol Plus top bannert and background are Jacked too...FYI...LOL Here I go Again... Mark@AmericanJeeper.Com
August 23, 20205 yr Author Admin Take a look at a new theme,clean look.this is a basic ips theme with the dark mode toggle functionality
August 26, 20205 yr Author Admin the slider is more streamlined,and i can add as many images as you want
September 10, 20205 yr Admin On 8/26/2020 at 3:38 PM, Mark R said: I have created a new theme,water elite prototype Sorry mate Ill take a minute and do a run through this am we all rained out but Mark had to work last two days anyhow only four of us worked yesterday but we solved a valve leaking issue on a couple of valves so thats a good thing... sorry man I have been out of charecter lately Here I go Again... Mark@AmericanJeeper.Com
September 10, 20205 yr Admin Ok im looking at the admin panel for now skin looks pretty good two things not sure if this is a doable thing or pain in the ass here goes...\ The banner logo can it be set to center or does it need to be left for the rest to stay put? The other thing is it possible to have smaller slider window like we used to have like half that width and size? I just uploaded 25 custom user images... these will be like what we will be running most times... Before I look if its all different sized chopped we will need to do one of two things... Get a size set of parameters most can get from a phone or simple camera... 🙂 Or auto size the image without losing skew and then no matter what image we use it fills the space nicely.. So now lets reload and see what we are working with... 🙂 Here I go Again... Mark@AmericanJeeper.Com
September 10, 20205 yr Admin Ok so can we size the overall image to fit? Based on what I am seeing so far our images are huge... Here I go Again... Mark@AmericanJeeper.Com
September 10, 20205 yr Admin Im running the update now I thought we did this one already...lol Notes for you sir... Nitro core → front → messaging → conversation core → front → profile → profile forums → front → index → forumRow core → front → styles → embeds.css core → front → styles → profiles.css core → global → framework → buttons.css core → global → framework → global.css core → global → framework → misc.css core → global → framework → popup.css core → global → framework → post-content.css core → global → responsive → tabs.css All American- Dark forums → front → index → forumRow Water Elite - Dylan core → admin → global → globalTemplate forums → front → index → forumRow Water Elite core → admin → global → globalTemplate forums → front → index → forumRow Water Elite prototype core → admin → global → globalTemplate forums → front → index → forumRow Tip: When viewing a template or CSS file from one of the links above, select Show Default from the dropdown to compare your customisations with the default for the current version. Affected Templates... LOLOLOL Here I go Again... Mark@AmericanJeeper.Com
